- Feb 19, 2013
- 220
I have acquired some unknown type of 1 inch steel from the surplus shop that I want to make a fly cutter out of. The blank is about 5 inches in diameter but had a piercing hold burnt into it when whomever had it to make a circle cut. I wanted to reduce the diameter to around 3.5 to 4 inches to make the body of a fly cutter. I copied the circle on the blank, used a bandsaw to cut as close as i could straight lines tangent to the circle so I would not have to turn excess steel. Here is the question... Should I grind some type of Right Hand tool cutter with an extended nose and attack the steel cutting a circle and facing the trash outside the circle off, or attempt to keep turning the no so round blank round in the lathe using a 4 jaw chuck?
