I am making a tracking device for astrophotography. The drive box will be 6 inches long and 2 inches top and bottom. It is my plan the top and bottom connect on the ends of the sides, The drive shaft will connect through bearings on the top and bottom.
The objective is to make the top and bottom as parallel as possible. This to me implies the sides should be of equal length and square. The exact length is less critical than the 4 side pieces be of equal length. My current plan is to cut the sides from longer pieces of 3/8 aluminum 2 inches wide.
I have a South Bend 9 with a milling attachment.
My plan is to cut the pieces as close as possible. Align the pieces on a surface plate and then firmly clamp them. Then carefully drill 4 holes near the corners and bolt them together. This should make a cube with the sides square.
Next I will square up the sides on the milling attachment and carefully mill the first end with the side of a large mill cutter. I will then flip the cube and mill the second end.
Is this a practical approach? Is there a better way?
