Just bought an older Starret inside mic set but it's off like 3 tho. the set came with a spanner wrench but for life of me i cant figure out where it goes, Does any one know how to calibrate this type mic ?
Starrett does not work like that.I just went out and looked at my SPI. The spanner engages in the screw holes, allowing you to rotate the barrel while holding the thimble.
no, I hadn't. I was concentrating on the 2 I needed now. but that was a great call. I went ahead and checked them all and your right. some are off more than others. so it has to be that you unscrew the rod tip to calibrate it. Going to try that this morning. still wish I know what the wrench was for lol.I’m curious, did you check all the different sizes to if there all reading .003 off ?
