- Dec 30, 2014
- 259
morning all,
I am going to build a valve spring compressor tool for a parallel valve Lycoming engine and the first step I want to try is making the "V" shaped fork that will rest on the spring and it gets compressed using a simple machine screw. So, how would you bend this? My first attempt was simply put it in the vise and apply force. Well, needless to say, it doesn't come out square and is difficult to control where the bends and flats end up.
It is cheap mild steel from the local farm store, 1/2 X 1/8" bar. Should be more than adequate for the task if I can get it bent.
My next thought is to mill a simple forming block pair and try putting it in the press. But before I start that I thought I would see what sort of tips I get from the group here.
Thanks,
Jim
Thanks,
Jim
