- Dec 19, 2013
- 73
I have a simple job to do but very little machining experience. I need to make some washers, 8 at 2" and 1/4 thick with a 7/16 hole and 8 at 1.25" and 3/16 thick with a 3/8 hole. I have a 1 ft piece of 2" hot rolled steel. I have thought of 3 ways of doing this.
1. Face off. Drill an undersized hole. Set up the tail stock. Part off the 1/4 thick pieces. Drill to 7/16 on the drill press. For the smaller washers then turn down to 1.25 diameter, part off the pieces and then drill to 3/8 on the drill press. (Tail stock because I am not sure if the 3 jaw will hold the material well enough for parting off.)
2. Cut 3" off the piece I have. Face, drill to 7/16, part off the pieces. Mount the remaining 9", drill to 3/8, turn down to 1.25 and part off the pieces.
3. Same as number 1. but do the 1.25 diameter pieces first.
Or ?????????? I would appreciate comments on what approach might be best, or how you would do it.
I have a 10" Grizzley lathe, converted to CNC. I also just purchased an insert type parting tool.
