I've had this lathe about a year now and for the first time last week I used the tail stock to center drill a hole in a work piece... I only have a 4-jaw chuck so I am forced to dial in all my work pieces before doing any turning. I diled in the piece and set up the tailstock with a .25" end mill to cut a .25" hole. Everything went smoothly but when I measured the hole it was .285" instead of .25". I had noticed earlier that day when parting off a piece that the cutter was low and left a tab on the end of the work piece. I set up my cutters by centering them on the point of the tailstock and assumed it was set at the center height of the spindle. Evidently my tailstock is .035" low. how to I set the correct height?
