- Nov 9, 2018
- 377
Getting ready to pull the knee off this mill, all of the dovetail ways are badly mis-aligned. The Z dovetail is angled at like 0.015 over 8”.
I’m basically planning to pull it off and secure and level it to something solid, like my workbench. I just ordered an 8” square frame level, graduated to 0.05mm/m (~0.0002” / foot).
I’ve never done this before, so not really sure what to mount the knee to.
My bench is solid welded 2” box tube, top is 1.25” steel plate with 3/8 mounting holes drilled and tapped, whole thing weighs about 1100 lbs.
So I’m thinking get some all-thread and 2x4 to build a fixture to hold the knee, then I suppose I need a way to make fine level adjustments on it.
I have the top surface of the knee scraped flat, so I’ll use this as a reference to line up the column ways and dovetails.
I suppose scraping it will cause the reference to shift, so I guess I’ll have to re-check the level each scraping pass.
Also the knee doesn’t look that heavy, I’m guessing maybe 100 lbs, so I can easily lift that by hand onto my surface plate and ink it directly.
Does this sound like a reasonable approach?
