This must have been discussed before. Sorry, but in searching, could not find an explanation...
I have a 4 year-old HF 4x6 bandsaw. Has suited me well. Changed the oil once a few years ago. It started to make more noise than usual. When I drained the oil again, the bronze worm gear is severely worn. I have the replacement worm gear in hand.
But, I do not see how to pull the worm gear off. I can't get a gear puller into the confined space.
I have seen people talk about an entire disassembly, starting at the drive wheel on the other side of the shaft. Is this the right way to proceed? I see there are multiple bearings in their that will need to get pulled and reseated.
But, is there a way to just pull what I see in the gear box straight out?
Thanks.
-Bill
Thanks.
-Bill
