- Aug 20, 2024
- 8
So not exactly a CNC question, but I'd like to add a power head lift to my Grizzly 0619 (Sieg SX 3) mini-mill. So far, it's all original, and I bought it brand new. It hasn't seen a lot of use, but I'm hoping to change that. Seems this is NOT an especially popular machine in the aftermarket, lots of options for machines with the head lift at the top of the column, but this one is complicated by having the handwheel at the front of the machine.
So specifically, does any one know how much torque it takes to raise the head, i.e. how big a motor do I need? And would I be better off with a DC gear motor or a stepper? Direct drive or re-use the existing gearing, I think it's a 2:1 reduction, or switch to cog belt? Also, what would be a reasonable speed? For short bursts, I can manage 5-6 IPM, but that slows down a lot if I have to raise the head very far. BTW, probably obvious but I don't use the handwheel for fine Z axis work, just to get the head as close to the work as possible so I'm extending the quill as little as possible. Another BTW, I've seen/read other ideas, bigger hand wheel or even a power drive at the handwheel, but I really want to dispense with the handwheel entirely, and get the lift mechanism on the column. Thanks!
Dave
Dave
