To convert an old Southbend Lathe to cut Metric TPI you use 127/100, 80/63, 47/37 Transposing Compound Gears, Ideally 127/100
My question is:
In a modern QC Lathe with metric or Imperial thread choices, Is the conversion exactly 1.27 or do they use a close approximation to make it easier to accomplish, do to the size of the gears?
Is it accomplished using a 127/100 transposing compound gearing internally or do they use a multiple of ratios through gears to reach a 1.27 ratio if it is exact conversion?
Just wondering if when we choose a Metric thread pitch by moving the appropriate leavers, are we getting an exact pitch or an a close approximation, and in 99.9 % of the time it is never noticed
I would assume it is exact, but is it really exact. You know what they say! If you Assume It makes an ASS out of U & ME
Thanks for your comments
My question is:
