It's hard to see but my set have a point at the movable side and another point at the fixed side but that fixed point has a fine V in it. If you have points at both sides then your mic will not be square to the thread will introduce cosine errors.The anvils in the mic currently appear to be pointed (for checking minor root diameter). That's why I suggested using gauge blocks.
