- Jun 12, 2018
- 724
I know it's not an accurate way to measure run out, but I indicated the surface of my 3-jaw chuck and I get around .007 run out.
If I put an end mill in the chuck and indicate about an inch away from the chuck, I get more than that.
How important is chuck run out?
I tried loosening the nuts holding the chuck and moving it around, retighten it, but that didn't do all that much.
Also, if you take out your 3-jaw chuck, is there a process you have to do to get it back on or do you just slap it on there after cleaning the mating surfaces and tighten the nuts?
