- Mar 28, 2012
- 4
Hello All,
First time poster. I am more of a Woodworker but I need some advice on a 45 degree set up Angle Block. I need some suggestions on what to buy and how accurate the Angle Block should be. BTW, I call it a block but it may have a more formal name. Here is a picture:
Maybe Angle Plate is a better name? Here is a link to the the Angle Block above: http://www1.mscdirect.com/cgi/NNSRI...re=ItemDetail-_-ResultListing-_-SearchResults. Is this one good enough?
Anyway, I have a piece of granite that is designed to be very flat and I am going to use the Angle Block to calibrate a gauge that measures squareness (90 degrees) for my table saw and joiner fences. The gauge also performs a number of other functions but measuring fences will be the Angle Block's primary function. Here is the device that I will be calibrating with the Angle Block.
The device for my table saw is the red bar with the dial indicator (which I own) in the guys right hand. The Angle Block that I want to buy is in the guy's left hand.
Anyone have a recommendation on where I can get an Angle Gauge for this type of set up? The Angle Gauge needs to be 1/4" thick and I need both the 90 degree and 45 degree capability.
Thanks, Bill
Thanks, Bill
