How do you set X or Y or Z to be something other that Zero?
Dataporter
Jan 20, 2013
285
Let's say I locate the edge of a part and I want to move 100mm while doing an operation. I know how to set the edge to zero, but can I set the edge to be 100 or -100 and then move to zero? IMO it's easier to approach 0 then 100. Then I can take advantage to the beeps as I approach zero, etc.
Obviously, I can set the edge to zero, move the 100mm and set that to zero, and move back to 100 or -100, but that is more steps... Thanks in advance Dave
Pre set button ?
Once you are centered over the edge (or other feature), tap the Axis value you want to change (0.011, in this case for the X-Axis), then use the keypad to change the value:
Hey @ycroosh This isn't the keypad I used to see - is this something that is now different on Fire Tablets (both of mine show it): it looks like the Fire is defaulting to the dialing keypad instead of TouchDRO's? It works, but can only add & subtract. I checked and this pad comes up for everything except the Hole Grid function, which has what I was expecting:
Fire HD10, Fire OS 7.3.3.0 checked 9/22/24, TouchDRO v 3.24.06 Build 2024-06-18 (HD 8's doing the same thing).
Oh boy, that's too easy... I would have sworn I tried that! Thanks so much!
The user manual for the app is very incomplete, but it does cover the basic and some common functions in decent detail. I recommend that you at least skim it. There is a lot of functionality that you won't just stumble upon until you go looking for it.
Also, watch this video:
It will at least get you started...
