- Sep 22, 2010
- 7,222
Hi Guys,
I'd like to use my little 4x6 bandsaw in the verticle position to rough out contours. One problem is that the thickness of the blades is .035, the width is .500.
Can thinner blades be used?
The length of the blade, at 64 1/2", means they have to turn in a very tight radius.
This is harder on the blade, to bend that tightly around the wheels. And it makes the welds more likely to break on narrower blades.
Will I have to change the guides for narrower blades? Will the steel wheels and guides flatten out the set in the blades soon?
Will I have to readjust the back stops to keep the blade teeth out of the blade guides?
As for the side bearings- should I pull em off, and replace em with chunks of solid steel or bronze, turned down to a thinner size?
Thanks,
Nelson
Thanks,
Nelson
