I never seem to have the right length screws and bolts. When working with mild steel or brass screws, I use my electrical strippers. They have a provision where you thread in the screw you want to cut and the tool makes a clean shear cut. When you back out the remaining screw the tool reforms the threads that may have been damaged. With a little clean up I'm usually good to go.
So, I had 4 - 10-32 x 1.25 SS socket head screws that had to be shortened by approx. .25". I tried the stripping pliers, but the SS was too tough and I did not want to damage the tool. I did not have a convenient way to hold these screws in my mill vise and same thing with my lathe.
So, what is the best way to trim SS screws and bolts that results in an accurate and clean cut?
Thanks, Frank
Thanks, Frank
