Greetings. Need basic help, please. I've disassembled all but one part of my Mori Seiki MS850 apron. Inexperience stops me short of going full gorilla on shaft 43 and two gears 41 and 45 held thereto in the attached diagram. I've already removed grub screw 42 from gear 41. Gear 45 is held to shaft 43 by a few roll pins on the 'rear' (bed) side, as I've shown in the attached photos. Shaft 43 extends through and rotates in the apron body.
How do I remove the gears and shaft? It appears that I could tap shaft 43 through gear 41 toward the rear side of the apron and thereby remove 43/45 as one piece. Should I press it out instead? I'm a little gun-shy because a screwup here would make this subassembly damaged and/or very hard to remove.
