- Aug 11, 2018
- 30
I am undercutting some transmission gears for a Honda motorcycle. I have a JET JDM18 mill and a Yuasa dividing head. I have an aluminum billet machined to hold the gear and the billet is held in my dividing head. How do I index each of the 5 dogs to the cutter so when I move the table left and right, I am getting a straight cut across the face of the dog? Current issue i have is, I have my dial test indicator held in a collet in the mill but it spins..... its not square to the table so my reading is off. I spend 10 minutes getting the face perfectly indicated in and when I looked down the side of the machine, the face was not parallel with the axis I was going to use to make my cut. I was off like 15 degrees. I am posting some reference pics from google for right now.
(Wont let me attach links to pictures)
If you notice, the dogs are pie shaped. When the gears are engaged, the dogs only mate about halfway down into the pockets so I can indicate down lower to get the most accurate reading. I just cant figure out how to get my indicator squared off of anything to get an accurate reading.
