I'm going through a pile of end mills and wondering if there is some way I'm supposed to be able to tell high speed steel from carbide or from all those various coatings? Half are unwrapped so all I've got is the writing on the shank and that's usually just the maker logo and the size. The other half are in tubes but not all are clear as to what they are made of.
For example, I find an orange cardboard tube with a Brubaker label: Special Endmill SE, 2 FLUTE HNA 1/2 DIA. F9A085 5122601 3-90. I assume 3-90 is production date, so those numbers aren't going to match anything I find on their website. What does HNA stand for? The endmill itself says #5122601 (so I think that's the model #) LEAD 2.243 BTC M7 OC. M7 sounds familiar, is that a type of metal? BTC?
And while I'm asking what are probably embarassingly easy questions - what is the lead 2.243? I see lead marked on a lot of endmills, but what is it measuring? (It's NOT flute length - I figured that much out.)
thanks
Joe
thanks
Joe
