- Jun 12, 2018
- 723
I want to make a screwdriver bit, around 4" in length with a 1/4" hex profile, with one end being a T25 Torx bit and the other being a T20 Torx
I have an idea on how to make it, but I don't know what cutter I need make the grooves. I was watching a youtube video of a CNC cutting and it looks somewhat like a gear cutter. I guess I can measure the groove with a gage pin and see what fits the best. It doesn't have to be exact as it just needs to fit into a torx screw and the tolerance doesn't have to be exact. I plan on using 1045 CR as I will be able to anneal it while machining and harden after I'm done.
