- Dec 18, 2019
- 7,333
My x-scale is missing counts. It loses over 8mm on 168mm of travel. How can I remove the scale from the mill? I didn't install it and there's no documentation on the scale installation. I removed the aluminum L cover and the M5 screws at the ends of the scale and it doesn't budge. I realize that the read head is attached still but it seems like there's something else holding it on the mill, like glue or other fasteners.
Have any suggestions? Had to scrap some parts because of this problem. Once I get the scale off, maybe I can clean it and test it. The scale seems to not count in a certain region. In any case, it's not possible to return to a datum, which means that the axis is NFG.
