How Can I Drill Into Hardened Steel Calipers?
Jeb1234
Feb 21, 2016
18
I'm trying to mount a cheap Lowe's digital caliper on my milling machine's quill for a quill DRO.
I've gone through 3 drill bits and two hss end mills trying to get a hole for a 8-32 screw.
How in the heck can I drill this stuff? I'm going with very slow rpms, cutting fluid and trying to put plenty of pressure on the feed but all I'm doing is dulling bits and end mills.
I can't heat it to remove the temper because I don't want to risk damaging the electronics and I don't really want to take it apart if I don't have to.
What kind of mill is it, Enco sells a kit to fit a caliper to BP type mills .
Got a pic of mill ,
OK, after a trip to Home Depot I picked up some Milwaukee cobalt drill bits.
50 rpm, heavy pressure and light cutting oil...got about 0.040" in before the bit dulled. Tried a second...no luck with cobalt.
Grabbed an old tungsten carbide tipped masonry bit, took a grinding wheel with a Dremel and dressed up the tip and tried it.
Same rpm, heavy pressure and cutting oil. Sounded like chewing on gravel, but it cut right through it with pretty little round holes.
This was definitely the hardest steel I've ever had to drill.
Thanks everyone. I now have a functioning quill DRO.
