I had an idea, and for once I can't find any example of it being done before, so I'm assuming it's probably a dumb idea. But I thought I'd run it by you all anyway. I need to mill a long groove, and I thought it was probably a good job for a horizontal mill, but I don't have one. Then I thought, a bar between centers on the lathe (live center in the tailstock), with an arbor cutter mounted on it, basically is the same concept as a horizontal mill. Lock the carriage, take the toolpost off, mount the workpiece to the compound, and feed in with the y-axis; sound feasible?
