- Mar 26, 2018
- 8,645
The Mickey Mouse set-up has to go.
I can't believe what I now have was engineered for this beautiful commercial saw.
I have a Marvel 612. It's old, it's heavy and it's built.
I want a simple belt adjuster.
Currently there is a 1/4 NC threaded hole in the cast iron. (see pics) The bolt I have in there now is just to keep the motor from swinging down and putting pressure on the belt cover hinges.
I could drill and tap the hole to a more substancial 3/8 threaded hole with a threaded rod that will allow me to move the motor back to the desired belt tension.
How are other horizontal band saw belt adjustments engineered?
I know it's a simple fix but I just can't believe this was the original set-up= too crappy.
Thanks
Thanks
