- Dec 18, 2019
- 7,422
I seem to have an issue with the scale not counting correctly. It appears to skip or lose counts. Today, when drilling some holes on my PM25MV mill, it seemed like there was a region where the scale wasn't updating, like it normally does. This miscount (or skipped count) ended up making me not drill the holes in the right place. When I returned to 0 it was in the wrong place. Ie, not directly over the edge of the part. It seems to loose counts going in both directions. To make this more irritating, this is my second attempt at making this piece. Both times, the holes ended up in the wrong spot. Out of 165.8mm of travel, my DRO only recorded 159mm. This time, I am positive it is the DRO, not me. The previous time, well, it might have been the operator, but it could have been the DRO is skipping counts. The feed rate in both cases was by hand and not very fast. 6 months ago, the DRO seemed to be fine, and I observed no problems even with a power feed.
Is this a typical dirty glass scale kind of problem? I looked underneath and saw some swarf up by the seal, but not a heck of a lot. Plan to remove the x scale and read head from the mill and try to clean it, but first I guess I will check for any loose fasteners. I'm out of my element here, and thought I ask others with a lot more knowledge on these scales. If this is the wrong place to post, I apologize. Thanks.
