- Dec 11, 2014
- 891
Decided to make a new Spindle Square last night as my first one was lacked an inch of reaching across the table front to back.
Used a piece of 1" square Aluminum 7 1/4" long.
Drilled and reamed two .373 holes a 1/2" in from each end for the DI's
Drilled and reamed a .497 hole for the 1/2" center post. Tight press fit.
Split each end with bandsaw for clamping DI's.
Drilled, counter bored each end and tapped 10 x 24.
Scallop cut where the DI's rested on holder to make turning dial easy.
Works good and it now reaches across table no problem.
Took about 2 hrs to make and put together.
