- Jul 14, 2017
- 2,455
I was recently asked to find a live center MT2 for a friend how has a small lathe, after looking locally with no success i've order one online and a week later got an e-mail they can't deliver, so if i can buy one i can make one, so i started with an 45mm round 4150 steel, which is overkill but it was closest to what i needed, first i chuck it straight and cut it down to 18 mm and 80 long, took couple of heavy cut and got beautiful chips with insert tool, then i set my compound for morse taper and cut the taper, then i flip it around cut the excess, face it and begin drilling it started with 8mm drill and drill it about 40mm deep, then i drill it with 29mm drill about 26mm deep then i used a boring bar to bring it out ti 32mm press fit, i'm using two 6201 bearings, then i made the shaft from some AR500 started with 14mm cut a 60 degree taper on one side and cut it down to 12mm for 22 mm and 16mm down to 7,8mm and center drill the end, i put in a ball bearing in the end fill it with grease and then press in the bearing and shaft, as last thing i made a cap form C45 and press it on, this is my first live center i've made, and i'm very satisfied, i'll update this thread as is being used how it holds up, and i hope to inspire someone, not to be afraid to make you own tools.
