- Sep 1, 2020
- 554
Great first lathe project, or experienced machinist project. A tool you will always be able to use. A 1.5” Boring Bar made from 4140 and designed to fit on your Quick Change Tool Post in one of your existing tool holders. Will hold any 5/16” Brazed Carbide or HSS Tool bit. The design could also be easily modified to make a smaller boring bar like a 1” or ¾” bar to hold ¼” tool bits. Really fun to make and no critical tolerances to add stress.
This was a very cost effective boring bar for me especially since it can be used for turning, threading, grooving or radius cutting in a bore. Most insert boring bars will only hold one type of insert and buying a boring bar this size for each of those operations would get very expensive.
I don’t see this design around anymore. I used one like this 25 years ago with a big chunk of key stock welded on the side of a round bar to hold it. Cutting the slots seemed like a good upgrade to the design to integrate nicer with a Quick Change Tool Post tool holder.
I hope you get a chance to make one. Great opportunity to use your lathe and your mill. Try out tools like a slitting saw and just have some fun making some chips.
