Guys while restoring my Sears lathe I got to a point and notice I had nothing to set it on.I wanted to get the bed mounted then put it back togeather and not have to deal w/trying to move it or load it on something later.So I put the lathe on hold and started on th base w/lower shelf for some added weight and made a pan for the shavings thats 48" long which is just short of the footing on tail stock end.First pic is just cut to size and marks layed out where I want to put the bends.
Took it to work today and using the sheet metal brake put me some 45* for the sides and front,the back is straight 4" high
The base I made out of 8"I beam and the three legs out of 2"x3"x1/8 tubing,the lower shelf has 2"x1" tubing to help w/bracing and support.
Its going to seat in place,and the three legs will have leveling rubber pads to help me get it perfect.Any ideals,its never to late and thanks for looking----kroll
