- Nov 25, 2015
- 9,776
A few years ago I wanted an auto compressor drain. But being too cheap to buy one, I adapted some stuff and made one. Today I noticed it wasn't working well, the problem was the filter was clogged. So I removed it, and then realized I should share it with you guys. So it has some drawbacks, one is that if you leave your compressor on 24x7 it won't work. It works when you shut the compressor off and it leaks air.. So that knocks out a bunch of you that don't have leaks. I do, I have a lot of plumbing going on. It feeds the wood shops, metal shop and garage. It's very simple and cost almost nothing.
It's HF mini filter and a couple of ball valves. The spring at the bottom of the cup releases when the pressure gets low, letting the water rush out. And when restarting the compressor it will push any remaing water out until pressure re-closes the valve. I've had it in use for 3-5 years...I don't remember how long..
Just thought I would share it with you guys. BTW I don't use wheels on this compressor, it's hardwired and just too big to move around, so I put it on blocks. It helped with the clearance underneath too.
Here's what I removed from the filter to get it going again. The filter was clogged from rusty water.
