The speed for honing and sharpening scraper blades (and similar work) needs to be down somewhere around 200-300 rpm for a 5" to 6" diameter diamond wheel. The power required is quite low for lapping scraper blades, so a small motor and belt or o-ring can work for a smooth running wheel along with an easier build and gearing. The pulleys are easily make for that application. Copy the Glendo for the tilting table arrangement, it works pretty well. If you want to grind carbide blanks into scraper blades, and carbide lathe and mill tools, then you will want much more power and more rpm, like a Baldor carbide grinder. For wheels, the Glendo ones with the embedded diamonds are very nice and last a very long time. The Chinese ones with plated diamonds are not as nice, and will not last as long, but are about 1% of the price and will do the job. Jeff, several members of our local group have made carbide lapping rigs. I am still procrastinating...
