Home Made 4:1 Belt Drive Reduction
brucer
Jul 30, 2011
348
I think I finished up my belt drive reduction assembly today, I'm running 4:1 reduction..
I'll look them over again tomorrow to make sure I didnt leave anything out, was tired when I got finished with them, had to just walk away..
I like the old school drilled I-beam look, I have a drilled I-beam going on my old 27 ford so I decided to drill a few more holes around the perimeter of the motor plate to fancy up the brackets a bit, plus its weight reduction ;)
IMG00573-20120220-2210.jpg IMG00575-20120222-1601.jpg IMG00576-20120222-2219.jpg IMG00579-20120222-2222.jpg
I ordered a set of aluminum gears from Motiontek in Canada and have been working on automating my feed on my lathe/mill combo. Its a Horrible fright 5980 but it has served me well for what I paid for it (nothing, it was traded for a debt I was owed). It uses the same XL series timing belt so if I can get the motor to turn slowly enough I will have added power feed to the X axis. Y is next. Then tie em together as an NC system.
Bob
