TTS collets are available for either MT3 or R8 IIRC, so you would need a spindle with that taper. I would personally go with the R8. Might check out a replacement spindle for an X2 or RF45 depending on the size of your machine. Little Machine Shop sells parts for the X2 and X3.
Go to Grizzly, a GO727 mill Spindle with R8, cost $51.50. You can also order the draw bar and pulleys if you want.
GO727
http://www.grizzly.com/products/Mini-Horizontal-Vertical-Mill/G0727
TO ORDER PARTS
http://www.grizzly.com/products/G0727/parts/HEAD-COLUMN
EASY TO READ DIAGRAM
http://cdn0.grizzly.com/partslists/g0727_pl.pdf
I have a Legacy Arty CNC router with a water cooled 3hp spindle. It uses ER20 collets.
When I asked, I was told they do not make one for the water cooled spindles.
They make one for Porter, Bosch, Dewalt or Triump router's that I use on my router table.
