So I'm contemplating making single tooth cutters for gear cutting on the mill. The toughest material they will probably be cutting is mild steel. I will be doing a caveman heat treat job. Like heat to straw yellow then quench in oil. No fancy equipment. They take the form of 1/4" square bar. I am getting a bit overwhelmed in the selection of steel for the cutters. I found a listing of tool steel that included 1018. The same outfit had 1018 bar stock listed in cold formed at a considerable savings. Are they different end products despite being the same alloy? Is either one suitable for a cutter shaped like the space between teeth and spun around impacting and cutting steel once per revolution? I'm new to tool type steel and need some help. What should I be looking for?
