- Dec 2, 2015
- 24
When rebuilding an antique tractor last year, I ran into an issue with the front axle pivot mount. The pivot pin is supposed to remain stationary in the mount, but over the years and who knows how many thousands of hours of field use, the pin had evidently gotten loose and wore the holes egg-shaped. I made this boring bar to use in my lathe to bore the worn holes round again. Building this tool required making a tool to use in making the tool to bore the worn hole! I needed to broach a square hole in the bar to hold the tool bit, so I made a square broach out of a 1/4" HSS tool blank, I ground it tapered on all 4 sides and then, using a Dremel with a cut-off wheel and an assortment of grindstones, I cut the teeth and ground the clearance for them. That was a tedious job! I did drill the hole a little over 1/4", 9/32" I think. When I pressed the homemade broach through the hole, it worked pretty good and cut a nice square hole, I did have to file it some until the 1/4" cutter would slide through easily.
Here is a video and pictures of the boring bar in use.
