- May 7, 2023
- 2,242
Ran into a problem making a die steel for one of our older dies and needed to reach back into my old school box of tricks to save my bacon.
Thought I could kill two birds with one hammer and fix this part, and also pass on a useful skill for making old things like new.
On a die steel this is kind of a bit of a hack, but like some are want to say, the difference between the professionals and the amateurs is the pros know how to hide their mistakes.
So, what got me here is the old worn out die steel I needed to copy apparently had some parallax issues in one dowel pin. This ment that even though my steel was a carbon copy of what’s left of the old steel, copying this error did not leave enough material to compensate for a few other issues I was fighting.
All I needed to do was bolt the steel in place snd shoot a new dowell, then proceed as planned.
Which I did, but it didn’t go as planned.
See that little half moon down there? Yeah, that needs to be the edge of a punch hole and my dowel hole impinged on it.
Oops!
This job got behind as there were other things to fix and being rushed I just went adjacent to the original dowel hole, and now need to erase that mistake.
Being this is a die steel and needs to be hardened I made a threaded rod out of A2 as the die steel is A2 so when I harden it everything will act as one.
This is important as I now need to insert a die bushing in place of a reamed hole. If this repair was just close I could get by without a bushing, but as is, having threads inside a reamed and hardened hole would be a disaster in the making.
I’ll spare you the threading operation and go right to fitting the threaded rod.
Here I’m test fitting it. I made the thread fit much tighter than if I were threading this to accept a nut, to help insure it will stay in place.
On a steel plate or casting I would just use all-thread. Done that more times than I care to think about.
Here I’ve threaded the hole to accept the rod and made a deep chamfer on each side of the steel to accept the peened end of the rod and lock it in place from both sides.
Chamfer with the threaded rod peeking out.
I left roughly 3/8” of rod sticking out to peen into the chamfer on each side.
Now it’s time to take out my frustrations over the mistake I made.
Time for the BFH to go to work
Iirc this is a 3# head. The steel is 9”x4” roughly.
I started with the “peen end” of the head, then used the ……. Other side to beat the snot out of it till it filled the chamfer evenly.
Now you’ll notice the hammer head has “NO NOT YOURS etched on it to prevent it from repeatedly winding up in my light fingered cow irkers tool box.
I’m lookin at you Jack.
Once it’s all nice and mashed down it will look like this.
Once this was done on one side, it needs to be milled near flush but left proud. This is so when peening the 2nd side, having the other peened end take the blow vs the body of the steel makes all of the threads expand outwards basically filling any voids.
Once that’s done I milled one side a few thousands below the surface as it’s going on the grinder next. Note that I’m also plugging the bad dowel hole with a dowel pin.
For a general repair milling flush is fine.
Next up, grinding it all flush.
Oops!
