- Sep 22, 2010
- 7,222
If you needed to weld 2 pieces of cold rolled steel 1/4" x 1 1/2" into a 90 degree angle to weld them with a Craftsman dual range 230 amp welder. I don't have any kind of jig to hold the pieces together. How would you do it?
Would you use your hand to hold them together? Push one piece against the other with a brick and tack it? Then would it hold enough to let me finish? Any suggestions on where to place the ground clamp?
The rods that came with the welder are 6011, 6013, 7018 and 8018
I have read 6011 is an easy rod to use would one of the other be better?
Thanks,
Nelson
Thanks,
Nelson
