- Jul 20, 2014
- 1,386
I'm planing a new Finger Plate for holding small parts and stock.
The hard part will be drilling a through hole after the V is machined at a 45° angle.
The steel plate will then be layed flat after the V cut using an and mill. I need the through hole to
be dead center of the V channel. Is there a way of re-locating that V's center line after it's moved to
a flat position w/o a DRO? If the table and vise are locked, will the drill fall on the centerline after the
part is moved off the 45° angle?
