I'm setting up my Taig mill using a HobbyCNC pro chopper driver and 23HS30-3006D steppers, 39V 11A PSU, LinuxCNC.
At first I thought it ran fine using 1/4 step, but then I checked the motion with a dial indicator and noticed that the motion was not smooth. I know the size of the microsteps will never be exactly the same, but this is much larger.
I did some testting and got these results:
Full step: move
1/2 step: move - stop
1/4 step: move - move - stop - stop
1/8 step: move - stop*7
1/16 step: move - stop*15
So regardless of the numbers of microstep set the stepper moves only once or twice per full step, resulting in correct motion only for full stepping. The result was the same for all 3 axis. For each microstep where there is no motion I can still hear the sound of the stepper changing. Current limit is set to 3A and I have disabled idle current reduction.
I don't think this can be caused by wirering the steppers incorrectly, as full stepping should not work either in that case.
I don't think it can be the motors, as I don't see how a faulty motor could produce these symptoms, and it in any case it should affect only one axis.
I don't think it's missing step pulses from the PC, as the pitch of the sound from the microstepper changes for each microstep even when there is no motion.
A faulty driver chip would be my first guess if it was only one axis, but all 3 seems very unlikely.
Anyone know what might be wrong?
Emil
Full step: move
Emil
