I was looking for a home shop welder last year and was all set to buy a miller 211 mig, and get a stick welder later, but ran across the ThermalArc 211i, 3 in 1 mig, tig, stick. I've welded with several different miller welders both mig and stick which all did a good job, but this 211i. In my opinion is so much easier and a much smoother arc than the miller 211 and a 304 xmt I had used.
for me it is the perfect home welder having a 200 amp Mig/ stick welder with a better duty cycle and being able to learn to tig is great. I use it on 220v but it has 110a max on 110v which is a big plus if you ever need it.
It is a bit more, at around $1200, than the Hobart on sale and the spool gun for the 211i is an extra $300 but for a 3 in 1 all around welder for the home/shop or farm I think it will do everything I need.
just thought you might want to look at the ThermalArc, now Tweeco, machines if you need more than just MIG.
