Finally, an area where I have some experience!
first, the O[SUB]2 [/SUB]concentrator uses a nitrogen dessicant that traps the nitrogen under pressure. Oxygen and trace gasses are delivered through the cannula. and there is a continuous compress and exhaust of the N[SUB]2[/SUB]. they are not as effective at altitudes ( at least they were not when I was a therapist.)
as noted previously, the liter per minute output would be inadequate for most torches. also, as the demand increases, the purity generally decreases. it can be a large or small difference.
the biggest problem is how you would then trap a sufficient volume and then compress that to be usable with a standard industrial O[SUB]2[/SUB] gauge? I think it would be impractical.
now for the largest issue, how many hours on the meter? if over 50K, the dessicant canisters likely need replacement. that would destroy the good buy. I suspect this is the case as a crappy used one is worth 250 to any low rent nursing home.
my 2 cents
kevin
y
- - - Updated - - -
According to the fellow who is selling it for his dad it will fill a bottle to 3000 PSI, so it is not a medical concentrator like the one I am currently hooked to. It is a high pressure compressor that compresses the gas to the point of liquefying it like our missile air on the missile system I worked on in the army. I'm going to look at it and see what it actually will do in the next couple of days or so and I'll report back what I find out. If nothing else and it is a medical gas machine like I have I may go ahead and get it to hardwire in the shop so I will have one that can get dirty if necessary. That would be OK too. That way if I touch it with dirty hands I don't have to clean it all up to go somewhere like the Dr or clinic.
Bob
I would love to see a photo of that! I have rarely seen a H cylinder filled beyond 2200psi, 3000 would potentially be exciting. I know they are tested around that on recert. if you did not have a safe way protect yourself form the potential energy conversion, I would be nervous.
If it is as the son says, it is a fractional distillation concentrator, but I bet it is a compressor for filling Large O[SUB]2 [/SUB]bottles from a liquid o[SUB]2[/SUB] source and expansion tank. very cool. take care to wear gloves and not even let oil from your hands get on the unit.
