A
Andre
Forum Guest
Register Today
My grandfather bought me a new style dremel drill press for xmas a number of years ago, I must have been 10 at the time. (Can you tell I am a tool nut!) and frankly, it's not useful at all.....for anything. I use it for endmill touchups, but it and my Dremel 4000 could serve a better purpose.
I have a '48 Bridgeport M head (with an interesting history), with bad bearings. For my work, it's plenty accurate but I can wiggle the spindle (quill up and locked) .005. Not cool! So I am thinking of attaching the dremel, and drill press in an upside down manner on the un-used side of the round ram. So I can swing it around when I need it....
Would this be a good idea? If it sounds too weak I can fab a mount but it'll be a pain. If I had an older dremel, I could make a new housing but my dremel has "speed compensation for heavy use" garbage that's supposed to add power when it gets bogged down. The circuit boards would be a pain to house internally....(could also use a flex shaft)
I intend to engrave a steel rule for a little toolmakers square I intended to make, with a 1/32" ball end "burr" (actually has tiny flutes, so it's not technically a flute, but you get the idea)
Any thoughts appreciated!)
