I have been using a 10 mm 2-flute coated carbide end mill for cutting aluminium and it does the job very well except for the relatively poor finish when doing side cutting. I don't blame it because the finish is mainly due to the rigidity of the machine ( the head shakes horizontally ). Recently I tried out a 3-flute , uncoated high helix end mill which is advertized to be great for cutting aluminium. The cutting edges are felt to be extremely sharp and the finish is better when doing shallow cuts. However, in deep cutting, the resistance to manual feed is clearly stronger indicating that the tool is not very effective in chewing up metal. Is that something expected for this kind of end mills ?
