- Jun 23, 2011
- 786
You saw it here first on HM!
I'm the proud new owner of the Harbor Freight 4x6 horizontal/vertical bandsaw. This saw is marketed by several companies like Enco, MSC, HF, Grizzly, etc. with various levels of quality and materials.
A big limitation of this saw (and most horizontal bandsaws) is the difficulty in holding short or small stock. This quick and dirty mod takes care of that....
Since the vast majority of cuts I will take are straight cuts, this mod is perfect for me. Because this mod affects the ability to cut miters, I needed it to be easily removable to return the saw to stock form. This mod has been prototyped using aluminum shop scraps, but will be duplicated in steel if and when the prototypes wear out.
The main problem cutting short or small stock is twofold:
1) The movable jaw rotates if the stock is too short to reach past the pivot point.
2) The fixed jaw is too short to hold small stock close to the blade.
The first order of business is to add a way to prevent the movable jaw from rotating. Rather than explain it, here are pictures which should be self explanatory.
What might not be clear from the pictures is that a shallow groove has been milled in the movable jaw to locate the anti-rotatation piece. This groove was marked by holding a 0.050 piece of rod stock vertically in the vise on the left side of the pivot. This was done to cant the movable jaw slightly towards the blade side of the fixed jaw ensuring good clamping pressure on small parts near the blade. In other words, slop would prevent the vise from holding small stuff because the movable jaw can still rotate very slightly. When tightened up on small stuff, the vise ends up square.
The anti-rotator was designed to be a snug fit in the bandsaw slot.
A more elegant version would be a flip-down anti-rotator that's hinged in a low lash fashion.
The second order of business is to extend the fixed jaw...
A V-groove was cut with a router bit in the mill to hold small screws and the like.
Now that all is done, it's time to test it out...
First I tried cutting short stock... This is a 2" diameter length of 303 stainless about 2 1/4" inches long...
Success!
Next, let's cut some small stock. This is a #6 x 1/2" plated wood screw. The goal was to cut it in two.
Success!
All in all, this project took about 1.5 to 2 hours to complete. To cut miters, all I need to do is take out 5 screws, remove the added parts and I'm good to go.
Cheers!
John
Success!
Success!
Cheers!
John
