- May 7, 2014
- 776
OK everyone , Maybe someone here has the "grey" H frame 20 ton press (seen here: http://www.harborfreight.com/20-ton-shop-press-32879.html )
The middle beam of the H sits on two pins. You can raise or lower this middle horizontal beam by sliding this up or down and simply putting in the pins on the vertical C beams. These vertical C (I think C) beams are so warped that I need to use a 3lb sledge to move it up or down. Obviously they are probably should be tight, and will loosen, but wow anyone else have one that tight? I went out and squeezed the vertical beams down a bit and they are better ,but now it's like a small s shape up and down. anyway, $154 and all a little banging around.... all good. thanks all!
CG
CG
