I want/need to make a 5/8” hex push-broach, but not exactly sure what to make it from…long section of a hex key or 4140HT hex bar? I only need 2-3 holes in total…1 each in some “pucks” of 3/4” thick 12L14 round bar.
Not knowing any better, I’m currently planning on making it from a long Bondhus hex key (only because it’s the cheaper option), but don’t mind spending a bit more if 4140HT is the better choice.
I assume (?) the 4140 will most likely be completely hard throughout, while I’m not sure if the hex key will be the same or just a surface case-hardening.
I wish they made hex in HSS…
