Help with V belts , required.
  • Thread starter Thread starter BRIAN
  • Start date Start date
B
BRIAN
Forum Guest
Register Today
After 2 frustrating days Googleing I think I need help.
When i modified my 7x12 to a 2ph motor i used the belt and pully assembly from a small chinese bench drill.
I now want to reposition the motor and require a longer belt
the original belt was made by HUANYU No K28 1080. Going to the makers site was no help at all, it has verv little info.
Also i cannot find any referance to belts of this section on any makers or supliers sites.
The section of this belt is Top 8mm--bottom 5mm--depth 6mm. I require a belt length of !000 mm
As i have not positioned the motor yet this can be varied a little.
Any help will be great, I just cant find this section belt at all!
Thanks Brian
Brian so far all I have found is http://www.beltsforanything.com/site80.php which is lacking in a bit of detail. Maybe the height is standard per width?
Tony's site in the UK claims to have nearly any belt for smaller lathes, including some 8mm top width: http://www.lathes.co.uk/page4.html
These guys list the K series belts, but not much detail otherwise. Probably requires an email inquiry.
http://www.vbeltplace.com/index_files/Cando - Power transmission - Wrapped V belt.Page 2.htm
Sorry I couldn't be more help.
Couldn't you make a pair of pulleys to suit a belt of a size that is readily available?
Thanks to all who answerd my call for help.
I have orderd the belt from, Belts from anything, and await delivery.
This company seems to enjoy giving the best service anyone could ask for.
at a good price. Will let you know the quality when belt arives.
Thanks again Brian.
Hi All
The belt is on and the lathe up and running
Thanks to you all and a Big thanks to Tony for recomending beltsforanything.com Its the best service i Have ever had bar none. even with the postage to Italy.
Regards Brian.
Well, I'm glad that worked out well, Brian. It's good to get a bit of feedback on a vendor. Thanks for letting us know!
I forgot to say that the belt is made by--- Speed control inc --- in the USA
Brian.
