- Jul 23, 2020
- 4
I'm designing two cylindrical parts that fit together tightly with hand force. My understanding is this would be a Locational Clearance fit. The nominal diameter is 94mm, and I am finding that a tolerance of 0.35mm is what should be expected for this diameter. If the smaller cylinder has an OD tolerance of 94mm +0.0/-0.35, then my calculation tells me the ID of the larger cylinder needs to be 94mm +0.35/-0.0, resulting in a fit range of +0.70 to 0.0 so that the lower end of the range isn't a negative value which would enter the light press fit category. But if the end result is near the upper limit of 0.7mm, wouldn't that be a loose fit?
I'm hoping somebody can give me some clarity on this... thanks..
