Hello everyone.
I would like to say thank you for all the help I've gotten on this forum by its members and I truly appreciate it..hope to one day to be knowledgeable so I can a answer and help.
I have a problem with my fine feed on this mill. The only thing that I have found is a worn beveled pinion gear located on the roof of the worm gear housing.. the two engagement gears for the up and down do not seem to be meshing.
The pinion moves when engaged but no contact. How do I replace this pinion gear, what is it called and can I replace it without taking the top apart? I included a photo of what I described..hope someone can help.
Thank you again
Thank you again
