Help With Dial Indicator Tip
The ones you bought are for use with a Starret back plunger-type indicator and will not work on the typical AGD dial indicators. Can you contact the seller and return it?
Are both female and have the same thread size? Use a 4-48 threaded set screw, screwed halfway into each to "bridge the gap"
Sent from my XT1053 using Tapatalk
If I recall, it is a different pitch thread on the 196 dial indicator than the standard 4-48 thread as on all of the others.
Ill end up buying the Starret I haven't found any knockoff sets that have what I need which is a wide curved point.
